i just started using dvdshrink to backup MY sopranos' and its just wat i wanted, not caring about extras or menu
is dvdshrink the best at re-authoring/compression of dvd9 to dvd5 (for wat i need - no menus/extras)
add - is dvdshrink the best at compressing large dvd movies to fit on a single dvd
just found the answer above!!!
dvdrebuilder > worth getting the pro version and why
Might be worth a quick look at some of the other forum threads.
You'll find I think that Shrink isn't really compressing your vid, and with episodes not really a lot of reasons to do so anyway. THat's not to say rebuilder isn't a good prog., just pointing out you might want to research a bit. -
Do you mean dvd2one is better quality than DVDRebuilder or DVDShrink, and are you comparing apples to apples, i.e. shrinking same size of files? I would think quality would be a function of amount of shrinking done and media quality too.
As compared to dvdshrink (yes, it was the same movie). I've never used dvdrebuilder, so I haven't been able to compare that one.
Google is your Friend -
Anyone who has tried them all will say that DVD Rebuilder is the best when it comes to quality, it just takes a while depending on the encoder being used and the number of passes. DVD Shrink is to be used when you cannot spare much time and quality is not an issue and/or the ammountof compression required is not to large. Personally I always use DVD Rebuilder, give it a try with HC Encoder.
Anthony
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 2nd Dec 2010, 00:07 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 18:17
